Could not enqueue message PDUs as the memory allocation of CRU buffer failed.
Collect data from the 'show memory' and 'show process erps' CLI commands. Check the memory usage of the system before and after issuing a 'disable erps' command. Restart/reboot of the switch may be necessary. If the problem persists, then this is an unexpected internal condition needing technical assistance. Contact technical support with the information obtained
Error
Memory allocation for CRU buffer failed for ring: %ring%
| Name | Type |
| ring | String |
